MicroStation CONNECT 10.14.02.01
Hi All,
I have self attached a saved view from the model to sheet of the same design file. However, the reference itself exist in a completely separate design file so, I am having to use a nested depth of 2.
Anytime I change line weight or color on the parent design file, it doesn't update on the saved view attachment I have placed on my sheet. Can someone please advise on how I can resolve this as I have also illustrated my reference settings in the image below:
Thank you
H
I believe that you need to go to wherever you created/saved the Saved View and update the Saved View to "see" your changes
MaryB
You need to set synchronize view to ALL and Display Overrides to Never.
Hi Barry...thanks for your help on this one. Meanwhile, if I set "Synchronize View" to NONE for specific purpose required by my current project, would it matter?
In my experience yes it does matter to ensure fidelity of the saved view. Having it set to none as a CAD standard sounds very strange.
Hi Mary, I have manually updated the saved view settings but the new colors and line weights are not reflecting. What do I have to do in this scenario?
