Hello All,
We recently switched from V8i to Open Utilities Map Connect Edition V10.13.0.48. I set up the keyboard shortcuts just like they were in V8i along with my position mapping. But when I hit 3-1 to copy on the number pad it gives me a selection from the ribbon. When I hit 3-1 on the numbers above the keyboard it actually copies. Does anyone know how to solve this issue so that when I hit the number pad it works the same as the numbers above the keys. My position mapping is below.
Thank you
I found this old thread: https://communities.bentley.com/products/microstation/f/microstation-forum/128352/numerical-key-pad
It could still be the same problem. Hopefully someone from Bentley can address this.
MaryB
The "Main" hot key's only work with task navigation if in U13 activate the v8i task theme. U14.2 and U15 have a MUCH better interface for task navigation and you can use dialog (v8i task navigation) or button menu (pre task navigation button row interface like to XM if memory serves). Both of these options will provide a "main" panel that is functional like to v8i.
-Grant
