I am trying to import models from a cell file. When I navigate to and click the .cel file, only the Default model shows. I know the models are there, I could see them a few days ago.
I don't know what could make your computer not see models in a DGN file, while other people can see them. As far as I know, there is nothing in a Workspace that would prevent you from seeing the models in a DGN file if they are there.
Hopefully someone with more knowledge than I can see this because I can't think of anything that would cause that behavior.
Can you post the file here, for others to see?Which version of the software are you currently using?
MaryB
Koog said: only what is in the image b
MaryB said:I don't know what could make your computer not see models
The caption to View 1 in your screenshot tells us that MicroStation is using Software Graphics. MicroStation does that when graphics hardware is inadequate and can't display properly. It's possible that a graphics problem may prevent other windows from displaying properly.
MicroStation requires a computer able to support Microsoft DirectX graphics. Check your graphics card installation: what hardware is physically installed, and what version of the graphics software driver are you using?
I am a 1 year MicroStation CONNECT Edition user (Version 10.13.01.01)
Jon,
I will look into your suggestions, and that seems like a good answer. However, I have been able to view the models before. Also, the other users have the same system and can see the models.
Koog said:other users have the same system and can see the models.
Do other users also see Software Graphics in their view captions?
Jon Summers said:Do other users also see Software Graphics in their view captions?
That's only going to affect the display of elements in a view, has no bearing on whether models would be listed in the models dialog.
* If models other than default actually exist I can't think of anything that would prevent them from being listed...
