When you open the toolbox from File>Settings>Tool Boxes and check Drawing Scale the dialog box opens. The problem is that its so small that theres no room between the close (X), minimize, and MS, buttons at the top so you cant grab it and move it to pin it to the top or side for quick access. You can click the M in the top left and click Move and you can move it around, but you cant dock/pin it anywhere. I like to keep it docked/pinned so I don't have to go through the clicks to open it and change the scale. Any help is appreciated, thanks.
Try pressing left mouse button near the periphery of MicroStation logo till you see the drag option. Once drag symbol is visible, you will be able to dock this.
A Defect 897816 is already logged for this to make the UI better for 'Drawing Scale' Toolbox so that it can be easily moved. If you would like to log a new service request, to raise its priority, do ask for it to be linked to this defect.
Ive tried this countless times, mine is too small and the drag symbol doesn't appear. The only way I can move it is to click the MS logo and click Move, but that doesn't allow it to be docked.
Hi Chris,
The Drawing Scale dialog has 3 sizes, SMALL, MEDIUM and LARGE.
You can right click anywhere within the Drawing Size dialog to change the Dialog Size.
You can also use the key-in DRAWINGSCALE SIZE (LARGE, MEDIUM, SMALL) to change the dialog size.
Regards,Ron
Answer Verified By: Chris Striba
That did it, I just had to make it Large so the grab icon would appear, thanks!
