I am encountering this problem everytime i'm exporting DGN to visible edges. Previously no such problem was encountered.
It says " MDL Loader: Could not load application e:\Builds\pp081109919\Source\msj\mstn\mdlapps\edges\edges.mc"
I am currently using microstation V8i, version 08.11.09.919
Any Suggestions?
Just to confirm, does that named file exist at that location?
MaryB
MaryB said:Does that named file [edges.mc] exist at that location?
edges.mc
No. That's an MDL source code file and the folder is an internal Bentley Systems development location. The error message is intended for internal consumption. We users should not see it.
Somewhere in the folder spec. is a reference to MicroStation/J (..\msj\..). I speculate that this is a misconfiguration on a computer where a (much) earlier version was or is installed.
..\msj\..
No, The E Drive is actually my CD Rom Drive with NO CD inserted or slotted in.
Do i have to reinstall microstation to solve this issue?
Jon Summers is correct in saying that something in your configuration is not working properly or is trying to locate this "edges.mc" from an old configuration. I suspect that you would need to be looking through your configuration files (UCF & PCF) for the workspace your using. It might be worth going back to the default workspace if you're trying to use a customized workspace, especially if it is referencing an E:\ drive which you say is a CD-Rom Drive.
Just to note that "edges.ma" is something that is provided with a default installation in the "As Needed" MDL folder.
"C:\Program Files (x86)\Bentley\MicroStation V8i (SELECTseries)\MicroStation\mdlsys\asneeded\edges.ma"
