one or more object enablers are missing
Hi
I have one cadworx dwg file with me. When i open that dwg file in Autocad 2014 software, i see some insulation graphics in it. But when the same dwg when i opened it in MicroStation 08.11.09.357 software, all those insulation (transparent objects) were missing.. When i check the message center window, i see lots of error\warning messages as follows:
I have real dwg 2013 version and also tested it on Microstation SS4 with real dwg 2016, but still the same result.
What am i missing in my  machine to see those insulation graphics in microstation?
Message Center Window:
One or More object enablers are missing.
Searching : D:\Samples\PAKAGE REATTORE.dwg
One or more Object Enablers is missing
Object Enablers are not required to open the file, but fidelity is generally improved if they are present. The missing enablers are listed below with information about the vendors that might help you find the enabler. If you believe you already have the enabler, verify that it is the correct version and properly installed.
Object Enablers are missing found for the following applications:
In file 'D:\Samples\PAKAGE REATTORE.dwg', Model 'Model':
Application: AecArchBase70
Product Desc: Autodesk Architectural Desktop 2007
Company: Autodesk,Inc.
WEB Address: www.autodesk.com
Enabler needed by 212 nongraphic objects, 0 graphic objects
Application: AecBase70
Enabler needed by 74 nongraphic objects, 0 graphic objects
Application: AecBaseEx70
Enabler needed by 10 nongraphic objects, 0 graphic objects
Application: AecSchedule70
Enabler needed by 2 nongraphic objects, 0 graphic objects
Application: LAN_AECSCHEDULEDATA
Welcome to ProStructures V8i Object Enabler CAL V8i (SELECTseries 6) - Version 8.11.11.55 Feb 11 2014
Loading module asdkhlrapi19.dbx...
Loading module c:\program files (x86)\common files\bentley shared\realdwg2013\prostructures.dbx...
Modeler DLLs loaded.
Loading Modeler DLLs.
Loading module c:\cadworx 2017 r1\plant\oe\19_32\cadworxplantacad.dbx...
Loading AEC Architectural Base...
Loading module c:\program files (x86)\common files\bentley shared\realdwg2013\aecarchbase.dbx...
Loading AEC Schedule...
Loading AEC Project Base...
Loading module c:\program files (x86)\common files\bentley shared\realdwg2013\aecprojectbase.dbx...
Loading module c:\program files (x86)\common files\bentley shared\realdwg2013\aecschedule.dbx...
Loading AEC Base Extended...
Loading module c:\program files (x86)\common files\bentley shared\realdwg2013\aecbaseex.dbx...
Loading AEC Base...
Loading module c:\program files (x86)\common files\bentley shared\realdwg2013\aecmodeler.dbx...
Loading module c:\program files (x86)\common files\bentley shared\realdwg2013\aecbase.dbx...
Sampath
Parents Reply Children
