Hi
I have a cell with a textfield that displays the Y-coordinate of one of the cells elements. It looks good when I place it in my DGN but when exported to DWG the value of the cell is set to 0.000 instead (which is the coordinate of the cells element within the .cel-file).
If I drop the cell it displays the correct value (but in wrong units, which I've mentioned in another topic).
DGN (cell left, dropped cell right):
DWG (cell left, dropped cell right):
Running powerdraft CE U15
Robert
Does this happen in any file or is it file-specific?
Can you provide an example file with just the fields as a test case?
Regie
1401.textfiled problem.dgn7026.textfiled problem.dwg
Goes for all files.
Thanks for providing the files.
What version of MicroStation are you converting the files?
If I open the DWG file you provided with MicroStation CONNECT Edition Update 14, the text field in cell looks fine.
I used Update 15. But looks like there's more to this. I guess the solution will be the same for both this problem and the one I have written about here:https://communities.bentley.com/products/microstation/f/microstation-forum/207663/textfield-unit-in-dwg-export/628442
Now I know this should work. I'll continue the discussion in the other thread.
