My clients are slowly moving towards Connect and with that in mind I to am slowly moving to Connect. Right now I have a problem with ACAD to Connect conversion. The converted ACAD drawing text, see before .png, is all stacked and in V8i you are able to double click on it and it would realign itself, see after.png. So the question is what or where is the solution in Connect to make this happen like V8i? .
What is the exact version no. (e.g. v10.x.y.z) of MicroStation that you are using? Use key-in VERSION to see the version no. in the MicroStation Message Center, or Help|About MicroStation in the backstage.
VERSION
John Watts said:I have a problem with ACAD to Connect conversion
Can you post a small example of the DGN file above-left? We need to understand how MicroStation has imported text from AutoCAD, and what it has produced in V8i after your double-click. Those things we can't see from a screenshot.
click the text, then drag corner handle to realign it. happens in Connect since its beta, no idea why only sometimes. I learned myself to live with it.
/pt
