A lot of questions here but I really need some answers after searching hard.
I work for 4 large clients. I need a way to set up each clients drawings so the drawing includes or has ready access to things such as dimension styles, text styles, and borders only for that client. I am trying to understand how to set up and use WorkSpaces & WorkSets. I have followed the instructions to create a workspace. After much searching and experimenting, I don't understand how to use it. I am familiar with all the folders and contents after looking at the Example WorkSpace that comes with the program.
When I am working with client files, do I put them in a new e.g., MyClient/DGN/MyClient-dgns, folder? While in MicroStation, how do I find and open the files?
If I create a dimension style, where and how do I save it for just that client's WorkSpace/WorkSet?
If I do create a drawing inside (or using) the WorkSpace, what happens when I send it to the client? They will not have that WorkSpace.
I do not have administrative privileges but we don't have anything set up. I see the value in it and I need to get something going.
You are using the workspace you selected when you open MicroStation. That's the workspace you are using.
I do recommend always starting the application before opening a drawing. If you simply double-click from File Explorer, Microstation will indeed open, but you haven't chosen a workspace, and the one it defaulted to may not be the one you want. You can only control that if you open Microstation first, THEN open a drawing.
MaryB
Once a file is open, you can click on the notebook icon in the status bar to find out what WorkSpace and WorkSet are being used.
Rod WingSenior Systems Analyst
I am not seeing the notebook icon.
Good to know. Sometimes it would ask what workspace I wanted and sometimes not. I didn't know what controlled that.
Either your Status bar is off the bottom of your screen, or the option is turned off.
1. Maximize the MicroStation window
2. If you still don't see the icon, right click over the status bar.Turn on the display of the Project field.
Answer Verified By: Koog
