I'm wore out from filing Service Tickets, they take forever and often go unresolved. Been using r15 for a bit now, new bugs, old bugs, I believe Bentley is using it's customers as beta testers.
A few things new and old that annoy me, new and old;
Compress file loses file functions, esp. reference files
No undo when using text command
Scale element by center no longer works for text elements
With an element selected, using the level manager to set active level no longer changes selected element
This is just a partial list, things from the last hour or so. Most all have work around, my entire CAD workflow is becoming a series of work arounds.
I will say this- Since updating to r15 I have not had Microstation lock or freeze.
Bob Rayner said:I will say this- Since updating to r15 I have not had Microstation lock or freeze
Hi Bob,
You're lucky. I have Microstatation CE U15 crash when switching from one file to another. This happens on a semi-regular basis.
--Robert
U15 crashes way more than 13/14 for me. usually when switching files
