Does anyone know what would cause your level library to be transformed into numbered levels? I logged in to a project file and all my line work was dropped and the name was changed to a Level #. When I clicked on the information tab, it showed the image below. In the span of two days this file was reverted. Has this occurred to anyone else or does anyone have a solution to this issue?
Would you be able to provide details for the version of MicroStation you're currently using.
MicroStation Forum best practices
Can you explain what you are meaning when you say you logged into a "project file"? Are you files located on a network or possibly within a Document Management System, like ProjectWise? Has this issue occurred with any other files? There is a possibility that the file may contain error so it may be helpful if you are able to provide a copy of this file for further investigation.
Could be file corruption. Try to do level audit.
communities.bentley.com/.../level-audit-levels-microstation
I've seen similar issue when using DWG as active file after Compress Design. the Level Display sometimes does not show any level, though Level Manager is OK. after MS is closed and open again, everything is fine. anyway, not sure if it has similar cause as yours case
/pt
