Hello everybody,
I am experimenting with notes and callouts to use them as labels in sheet views. I am using a text favorite to "readout" an element property.
I was wondering:
Is it possible to place a callout with two clicks like a note with a leader?
Right now the callout gets placed where I make the click to get the association of the element, but I would like to place it with an offset to the element I am labeling.
So first click would be to get the association and to read out the element property, second click would be to define the position of the text. And I don't want to have a line between the object and the text.
(MicroStation - Version: 10.14.02.01)
Currently using:
OpenPlant Modeler - Version: 10.08.00.51
[MicroStation - Version: 10.14.02.01]
Apologies for the delay in response to your query. I have raised the following Enhancement to our development team to consider the inclusion of this suggestion.
Enhancement 1129777: Place Callout - define position the same way as notes with leader
Answer Verified By: Florian S.
