My raster image starts turning solid white as I zoom in. The closer I zoom, the more of the image turns white. It is impossible to edit.
Not sure whether this is a duplicate discussion but it appears you have another post that looks like it is regarding the same issue.
https://communities.bentley.com/products/microstation/f/microstation-forum/208332/attached-raster-seems-to-move-when-zooming
When posting your questions you should always mention which software and version is being used.
https://communities.bentley.com/products/microstation/f/microstation-forum/87312/read-first-microstation-forum-best-practices
Is it related to the use of a CIT format image as discussed in the other post?
This may be related to the graphics display on your system so it may be worth going through the following checks and ensuring you have the latest version of your graphics card driver.
https://communities.bentley.com/products/microstation/w/microstation__wiki/13543/troubleshooting-graphics-display-issues
can you post a small dgn example and raster so we can test on our own machines and see if it works for us...or its just yours.. might narrow it down a bit...
Lorys
I have asked the other drafters in our group. Most have seen the same problem. I have prepared a file that shows the same behavior. How do I upload a dgn?
If its more than one file we normally zip it up, then when you use the reply button , below the dialog box is Insert(down arrow) > insert image/video/file then down arrow select > File upload>browse then this lets you browse to your zip or other files and when it finds it select ok ..that's all there is to it.. so if it's not a security issue or confidential data this is the normal way we upload stuff..
We even use it to upload screen shots so we don't lose picture quality copy paste images come out very poor quality don't do it..
Hope this helps
At the bottom of the little window area where you type your reply, there is an option for "Insert". One of those choices is "Insert Image/Video/File".
MaryB
