In the new version of MS V8i how can you convert a dwg to a dgn?
mu current version of MS is
Name: Bentley V8i (SELECTseries 10) - Autodesk® RealDWG 2016 Vendor: Bentley Systems, Incorporated Version: 08.11.09.919 Type: 32 Bit Installed: 09/24/2020
You can open DWGs straight into MicroStation, and SaveAs from there, but with that version of MicroStation, it only works on DWG files 2016 format and older. If you have a newer DWG format, it cannot be read by that release of MicroStation. You will need someone who can save it "back" to an older release DWG.
MaryB
Or use the free DWG Truview app from Autodesk for translating to an older DWG version.
thanks F. Mandoki, I got the 2021 Truview but was not sure how far back to translate the dwg.
Larry Smith said:I got the 2021 Truview but was not sure how far back to translate the dwg
Look at the History of MicroStation. It mentions the version of Autodesk® RealDWG supported by each version of MicroStation.
thanks Jon, will do
