Hello!
On Powerdraft CONNECT the level manager icon is not working. When I click on it, no window appears. The only way to open the level manager is to click on the small arrow next to it and to open the flyout window. No chance to change the size of the flyout window though.
Does anyone know how to solve this?
Thank you and kind regards
Hannes
Hi Hannes,
a few more details would help to analyze the issue better:
With regards,
Jan
This issue is most likely associated with a dialog box that has been dragged off the edge of the screen. The easiest method of retrieving the dialog box would be to locate it under the Window List in MicroStation. You can open this by keying it into the Search Ribbon option or selecting the Windows List tool from the Primary ribbon.
https://communities.bentley.com/products/microstation/b/microstation_blog/posts/microstation-connect-edition-39-s-integrated-ribbon-search
If the missing dialog is not listed, you may need to reset MicroStation back to the default settings. To do this key-in the following at a command prompt:
"C:\Program Files\Bentley\MicroStation CONNECT Edition\MicroStation\microstation.exe" -restoredefaults
(or whichever location has been selected for the installation of MicroStation)
http://communities.bentley.com/products/microstation/w/microstation__wiki/8671.restore-microstation-to-factory-defaults
This should reset everything back to default so the dialog boxes reappear.
You can open a Command Prompt either from:
> Start Menu > All Programs > Accessories
or
> Start Menu > Run...
If you require further assistance do not hesitate in contacting us.
Thank you very much, reset to the default settings solved the issue!
