I have two levels that I want to merge into a single level, similar to Autocad's "Merge selected layer to" or LAYMRG command.
using MicroStation CONNECT Edition Update 14 - Version 10.14.00.109
thanks
go to the level manger pick the level to move and right mouse REMAP and it will bring up a dialog listing all available levels pick the destination and it will move all te objects to that level but if all your elements are not BYLEVEL ( like acad bylayer) some elements may not take on the right symbology.
Alternative method
turn off all levels except source level and destination level ... now turn off the source just for a second and now match all the properties of the destination level now turn on the source level select everything with a crossing window or through the powerselector the level name and now use the change tool with all the active attributes set how you want and data point to confirm then deselect you will see now the number of elements in the source should be Zero elements. You can choose to delete the empty level or just leave it off and frozen, I prefer use the compress and remove empty levels...
Lorys
Answer Verified By: Nicholas Ball
Hi Nicholas,
REMAP tool, mentioned by Lorys, is equal to key-in
LEVEL ELEMENT MOVE [dest:level-spec2] <level-spec1> for example LEVEL ELEMENT MOVE dest:target_level level_to_be_cleared and when names with spaces exist LEVEL ELEMENT MOVE dest:"my new level" "source level"
With regards,
Jan
Alternately you can just create a selection set of the desired elements, then select the desired level in the ribbon attributes tool box. (NOTE- Selecting level in the Level Manager should do the same thing but no longer works (bug)).
perfect, the REMAP option was exactly what i was looking for.
