Hi All
I have managed to do something in CE U15 with some setting, saving or something with view attribute dialog box. When I open the view attributes the dialog box is super size, from screen edge to screen edge, the dialog box do not even only fit the active CE U15 active program limits.
How do I reset this to be normal dialog box again (as in SS versions) and what did I do so this happened? Has some one else had an similar problem?
//Tom
You should be able to "grab" the lower right corner or right edge and drag to re-size. It is a bit touchy.
Hi Bob
I managed to do that (I can re-size with command ctrl +B ) but it did not save my re-size to the next time I opened CE U15, and it did not either "locked" the re-size dialog to the "B" symbol or in View dialog place., see image attached
This is example images from SS10 how it should work in CE U15
How it works in SS10 may have nothing to do with how it works in CE15
MaryB
