Hello, I try to add custom display style to seedfile, I followed the explanation from the wiki : https://communities.bentley.com/products/microstation/w/microstation__wiki/26898/how-to-import-a-display-style-from-a-dgn-to-my-standards-dgnlib-file but with the connect update 15 I'm not abble to find the Office_Standards.dgnlib. So can someone can explaine how to add a custom display style to all the file ?
Thank you,
Fabrice
The Wiki talks about adding your created display styles to the already available DGNLIB file (Office_Standards.dgnlib) . This file is not delivered but you can create your own. ( create a blank DGN file and rename it DGNLIB )
If you have your custom Display Styles created in a *clean file* you can rename it as *.DGNLIB & point the MS_DGNLIBLIST variable to it. This will show the display style in all the files
If your file is not clean i.e. it has levels , text styles..; it will show all the levels, text styles ... in all your files.
The wiki shows how to only move the Custom Display Styles from you files to a DGNLIB.
Answer Verified By: Fabrice K
Hi Nilesh,
Thank you very much, now all is ok, I have the personnal display style on all my file.
