My company upgraded from v8i to Connect last month. After a painful month of not knowing where anything is in Connect and having to change ribbons constantly I have set up a custom ribbon to basically mimic the setup with position mapping shortcuts from v8i. So Element selection is '1', I place a fence by typing '2-1', stretch an element by pressing '3-8', etc. For some reason, though, the number line above the keyboard is not working to access the position mapping. I have to use the number pad. I'm not really sure what's going on with this. Any thoughts? I'm attaching an image of my custom ribbon along with the position mapping settings.
What is the solution?
As above, make sure you use either the number pad to map or the keypad to map. Both will not work.
I've tried using just the number line when typing into the position mapping setting and still not getting it to work.
