I have been trying to install Powerdraft (connect edition) on a pc for a couple days now, and I have been getting nothing but "Failed to install MicroStation PowerDraft CONNECT Edition with error code 0x80070643. Fatal error during installation. I've looked up the error code, but got nothing related specifically to powerdraft. Is there anything I can try?
Hi Ian
When you install PowerDraft Connect, are you running it from the install file that you download from the Bentley site or have you or someone else created a deployment?
Also when you install do you have ADMIN rights?
Ian
Possible PC not up to it?
My pc has plenty of power to run it, so i dont think thats it.
Im installing from the install file from the Bentley site. I will try installing with admin rights.
Did a bit of searching. No threads with solution. Clues include looking at the Microsoft .NET software, it may be corrupt or need updated.
