I've set microstation connect to open 2 application windows.
However only 1 opens.
I have closed microstation and reopened.
The operation setting is still set to 2 windows but. as I say, only 1 opens.
What can I do ?
Hi Fraser,
It will show 2 windows when 2 screens are detected.
Did it show the 2 screens earlier . Is it the first time you used it ?
Thanks Nilesh.
First time.
It is a laptop with an extra screen added with HDMI cable
Hi FraserG,
Please review the following Wiki https://communities.bentley.com/products/microstation/w/microstation__wiki/14927/setting-up-microstation-to-use-dual-display
and this thread https://communities.bentley.com/products/microstation/f/microstation-forum/156346/dual-monitor-issue maybe you need to Maximize the application window on that monitor
Maria Garcia
There could be a few settings on your laptop that could affect that.
It's also possible that your second window is opening directly under the first. I've chased that more than once. See if you can minimize the first window. If there is indeed a second window "under" it, you can drag that second window to your other monitor
MaryB
How are your multiple displays configured?
In the Display Settings verify you have the Extend option selected. The two applications windows probably won't work with any of the other options selected.
Rod WingSenior Systems Analyst
