How do I add a signature at the end of each post (to show the Microstation version I am running)
I see I can add a signature to my profile as a popup, but what about an option to add a signature at the end of each of my posts, to show the version of Microstation I am running.?
go up to the icon of your login and select setting then once its open scroll down to signature after dont forget to scroll down further to find the save button
... however I think its also best to put it in the heading of your post when you post questions so we can see straight off ie if you post CE .. I'd probably read it later as I'm more experienced in V8i and could answer most of the questions people have because over 25 years I probably had the same issue or problem at least once.... so I'd read and help those v8i ones as a priority....
Lorys
