Hello I am new to using the "bentley microstation" software. is it possible to create labels with a background, the text of which adapts to the height and width. and that we can change the color of this background and the text.
. thank you and sorry for the translation
You can get it with additional clicks using notes with text frame box and then adding a fill to the associative region. More of a workaround and I have not used it myself, because notes are always a hassle to get right, but the frame of a note changes fitting to the text when you change it as far as I know.
Here you can read more about it:
How to place a Filled Background in a Text Frame with Place Note - MicroStation Wiki - MicroStation - Bentley Communities
Currently using:
OpenPlant Modeler - Version: 10.09.00.74
[MicroStation - Version: 10.14.02.01]
Thank you to everyone. I'll try to find a solution ... but what a pity. thank you
let us all know what you figure out as we all want this for a long time from v8i and maybe before...maybe needs a custom vba... seems to be the solution to all bentley not making timely fixes
Lorys
