Just moved over to the Connect version finally. I usually use the properties window to move text that may not be snapped in the right location on the grid (example: I use a 0.05 grid spacing, so if a text is sitting at say 0.057, I would use properties to move it over to 0.05).
I recently tried to move some text that had shifted off of the grid and found that I can no longer edit its location via properties. Seems odd. Is there a setting that is preventing me from doing this?
There area couple of suggestions I can think of:
You might like to provide some screen captures showing what is happening or an example design file.
