I have a file (model) where all settings are well defined -- and a couple of similar files (models) where this is not the case.
What is your best way to copy the settings over?
Maybe you want to change a particular setting and distribute it to the rest of the files.
Yes, that is what I sometimes do. For single files. But if you think of a batch of files and at some point you want to change some settings (e.g. raster, units etc.) a bit differently throughout the project. I thought sb. would have a easier route. Some "copy settings from model". Maybe I will put it into ideas.
Thanks for your answers.
