I'm trying to export points with coordinates from MSTN v8i ss5 to Rhino 6. The Microstation file is centered around GobalOrigin (0,0,0) with units in mm and the test object is about 10x10 meter. Rhino can import DGN and the units are set to mm, large objects. However, the coordinates are inflated immensely, about 10^6 times. Any clue how to get it right? I will post the same question in the Rhino forum. Greetings, Ingemar
I am thinking that this issue is probably related to the operation of the Rhino software rather than MicroStation. Also, there is no such version as V8i SS5. Could this be related to another Bentley software package? Have you had an answer from the Rhino support forums?
