Failed to converge error when using Spiral Between Arcs
Hello all,
I am trying to show a spiral curve between two arcs.  The arcs are fixed in place and one arc is contained 100% within the other arc, and I need to connect them with a spiral.  While using the spiral between arcs tool, I get the error "failed to converge".  What am I doing wrong?
