However, it seems that in Connect the "View previous"-command is limited to 20 steps.
In V8i I cannot recall such a restricting limitation. Is it possible to go further back than only 20 steps?
Andras Dähnrich said:Is it possible to go further back than only 20 steps?
It's not possible. The 20 limit was chosen because it seemed like a reasonably high number that didn't needlessly waste memory for view delta states that would never be accessed.
Instead of clicking view undo more than 20 times, you might want to consider creating some saved views?
HTH
-B
So something was possible in 32bit V8i became impossible in 64bit CE. Such improvement.
Yes, it was an improvement to put a limit on the memory used for view undo to 20 for each of the 8 views.
Do you really click the view previous button more than 20 times? Raising the limit (or even removing it) would be trivial, but I question the use case that requires it.
Thanks for your comments.
Working with dozens of references inlcuding houndreds of levels, permanent zooming and scrolling it is common practice for me.
Working with saved views takes to much time.
If it is trivial to raise or even remove the limit, kindly advise, how to do so.
Andras Dähnrich said:If it is trivial to raise or even remove the limit, kindly advise, how to do so.
It's not something you can change (refer to my original reply).
The "trivial" comment was directed at the other poster in regards to changing the software, I apologize for the confusion.
