I have created a cell and I have attached an item type to one of the lines within that cell.
When I place the cell it seems I cannot right click on the cell and ask 'Edit Item'.
Only way I did found is drilling down in the properties pane to the correct line. Then I can change the properties. But this is very cumbersome..
Any way to easily change the properties ?
Thanks for any input.
Luc Dierick
Hi Luc,
Luc Dierick said:Any way to easily change the properties ?
I think there is no simple way, unfortunately. As Oto wrote, old tags are still better in this situation (or more precisely, Item Types are better, but available tools are poor).
My question is: Has to be Item Types attached to an element inside the cell? When Item Types are attach to cell itself, they can be edited easier (directly).
With regards,
Jan
