I'm working on dimensioning. I have set up a Dim Style in my design file and I refenced in my base file of a roadway wading I am working on. When I try to dimension the base file using Dimension Linear and select the option do select multiple all of my dimension are where I want the but dimension nothing they are in space.
Thank you,
Armando Luevano
Hi Armando,What MicroStation you are using? Is this happening only with one file and if so can you attach it?https://communities.bentley.com/help/w/be_communities_help/4413/communities-forums-best-practices-and-tips
Morning Robert,
I am using MicroStation V8i Select series 10 and its only happening on this one file. I can not attach the file I am working do to its sensitivity of the work. I am using living nesting on the reference file.
If I use single linear dimension and go from center line to water line, eop, boc, etc...it works but when I try do select multiple elements to dimension it select the end point of the lines to dimension and does not show the dimensions correctly.
