I am trying to access the level manager to edit properties of certain levels. When I press the button, it does not open. I have tried opening it from the search bar however it still doesn't open. I have also tried to open it via Level Display by right clicking and selecting Level Manager which failed. I seem to be able to access every other feature fine.
The Level Manager has worked for me fine in the past until recently it suddenly stopped. I can not think of any settings changes I have done that would affect this.
Any help would be greatly appreciated.
Many thanks,
Jody
Hi Jody, Which version of MicroStation you are currently using?It's possible that Level Manager dialog is open but is placed at a position on your screen that it's no longer visible. communities.bentley.com/.../dialog-box-cannot-be-moved-or-located
Try to temporarily lower down your Windows resolution by one step. This will force all dialogs to be repositioned and can make hidden dialogs pop back.
Perform a RestoreDefaults and check if you can access the Level Manager
Karan,
I am using MicroStation CONNECT Edition Update 6- Version 10.06.00.38.
I have tried the resolution trick however it did not work. I also tried changing the size of the MicroStation display window however it was not there.
I will attempt this later as it requires my company's IT admin details. Are there any other methods I can try in the mean time?
Try these key-ins...levelmanager dialog toggleleveldisplay dialog toggle
