Multiple Active Cells in Element Templates
Hey everyone,
I had a question. I notice that I can assign multiple cells to an element template. However the place active cell tool only uses the first one in the list. Is there a way to cycle through all of the active cells to select the one you want? If you look at the active cells in the cell settings it has a Cell[0], Cell[1], Cell[2], etc. This suggests that there's a way (at least buried within the software code) to cycle through which one of these assigned cells becomes the active cell. see the image below for reference.
