I've been on google for a while now and not being able to find my answer. I'm thinking I either don't understand the google results or my question hasn't been asked yet. I'm looking for a way to cycle through snap-modes. Fx [CTRL] + [Mouse wheel] for cycling between "near snap"/"keypoint snap"/"midpoint snap" and so on and so forth.
I'm using Microstation Connect.
Best regards,
Jacob Collstrup
Why do you want to do that? Wouldn't setting up a 'Multi-snap' with the options required make sense?
In addition to the multi-snap suggestion, there are also the keyboard shortcuts. I typically leave keypoint snap active and use keyboard shortcuts to change the snap mode for the next data point.
C - Center
N - Nearest
I - Intersection
K - Keypoint (can change divisor here to)
There's no built-in way to "cycle" through snap modes (there's quite a few snap modes and there are probably only a few you use regularly)...
-B
Brien Bastings said:In addition to the multi-snap suggestion, there are also the keyboard shortcuts. I typically leave keypoint snap active and use keyboard shortcuts to change the snap mode for the next data point. C - Center N - Nearest I - Intersection K - Keypoint (can change divisor here to) There's no built-in way to "cycle" through snap modes (there's quite a few snap modes and there are probably only a few you use regularly)..
But these don't always work. Quite often when starting a tool I have tried to use a shortcut to get to a particular snap and it doesn't work. I then have to rethink how to get to where I want.
Stuartw - when you say 'these don't always work' - does AccuDraw have focus when you enter the shortcut? If not, the shortcut is not recognised.
stuartw said:But these don't always work.
To use keyboard shortcuts, make sure focus is either at Home or the AccuDraw dialog, and if it's not hit ESC, F11, or F12
