I got my Delta terrain model in 2D with a Thematic Height Display. I've set the minor contours with text on.
the problem is that the text is displayed half behind the triangles from the Thematic Height as seen in the picture.
How can i get the text to show up in front?
And
The legend won't show up in my 2D view, but when i set the display style in 3D it shows up.
How can i get the legend in 2D?
The Thematic display style is available only in 3D model.
We can reference a 3D model ( having a Legend placed as a element ) in a 2D model & then view it as thematic using Reference Presentation.
are the Minor Contours on a different levels ? Have you tried setting them Priority ?
Nilesh S said:The Thematic display style is available only in 3D model.
I got the Thematic Height in 2D as an extended display style for my Delta Terrain Model so its visible in 2D.
Nilesh S said:are the Minor Contours on a different levels ? Have you tried setting them Priority ?
How do i set them to priority?
Thanks for the information Rick. Try setting a Wireframe Display Style to the View with "Use File Order" = ON.
This should display the complete text in the contour
Answer Verified By: Rick Bol
Rick Bol said:The legend won't show up in my 2D view, but when i set the display style in 3D it shows up.
Thanks a lot!
This answered my question for the text display
Rick Bol said:This answered my question
Please mark your thread as answered.
Rick Bol said:Is there a way to get a legend in 2D or is this only possible in a 3D view?
Don't hijack your own thread! Start a new question.
