I got the Thematic Height in 2D as an extended display style for my Delta Terrain Model so its visible in 2D as seen in the picture below.
But i cant get the legend to show up in my 2D view.
Is there a way to get a legend in 2D or is this only possible in a 3D view?
The Thematic Height Legend is something that would only be available to display while working in a 3D model.
When this legend display it is usually a temporary legend but the Thematic Display Dialog has an option where this can be displayed as Persistent Element.
This may not help with the display in a 2D model but allow you to copy it.
Thematic Display Dialog, Legend Tab
In addition to Andrew's response you could also place the Legend as a 'Persistent Element' in the 3D model and Reference this into the 2d.
Carl Myhill
Technical Support Engineer
Bentley Systems
Andrew Bell said:This may not help with the display in a 2D model but allow you to copy it.
Hellow Andrew, Thanks for your answer.
I just dont understand what you mean when your saying you can copy it? Copy it into my 2D model or onto a PDF?
Hello Carl, Thanks for your answer.
This doenst work for me. When referencing the 3D model with the legend it still does not display in 2D
Did you place Legend as 'Persistent Element' ? ( Tip Ensure you placing the Legend within the range of the Model otherwise this may affect the range of the legend)
Is the Reference cached ?
