Good Morning,
When I dimension in a MicroStation Drawing I cant snap to points of a DGN reference, as shown below.
I would like this dimension to a point shown in red colour.
Please can somebody advice if there is a setting that I haven't turned on to make this possible?
Thanks in advance,
Andrew G.
Hi Andrew
Do you have the snap option on in the references dialogue?
See more here:
docs.bentley.com/.../Reference21.html
Hi Grzegorz,
Yes I have the snap option on in the reference dialogue.
Andrew G
please try to set a different snap mode, e.g. Multi-snap and test with that:
Best regards,
Andrea
Hi Andrew,
Make sure that the references you are wanting to dimension are set to cached and not dynamic.
Hope this helps,
Andy
Answer Verified By: Andrew Gratton
Thank-you Andy,
That solves the problem.
