I need a key-in to set the model Line Style Scale properties to Compound Scale. I've found may key-ins for different model settings, but not for this one. Is such a key-in available?
please read and follow the best practices: It's often impossible to answer a question without knowing what product and version (build number) is used exactly.
PH said:I need a key-in to set the model Line Style Scale properties to Compound Scale.
I think such key-in does not exists. But maybe simple VBA macro, using PropertyEnabler, could do it.
With regards,
Jan
As suggested by Jan there is no key-in
Following is a VBA snippet to change active Models Line Style Scale to “Compound Scale”
Sub ChangeLineStyleScale() Dim sMsg As String Dim oPH As PropertyHandler Set oPH = CreatePropertyHandler(ActiveModelReference) If Not oPH.SelectByAccessString("LineStyleScale") Then Debug.Print "LineStyleScale Access String NOT FOUND!!" Else ' 0 = Global Line Style Scale ' 1 = Annotation Scale ' 2 = Compound Scale oPH.setValue (2) sMsg = "Active Model LineStyleScale changed to '" & "Compound Scale" & "'" MessageCenter.AddMessage sMsg End If CadInputQueue.SendCommand "FILEDESIGN" End Sub
I was unaware "compound scale" was even an option.
What are the benefits of a compound scale as opposed to a simple "global scale"?
MaryB
Please check the following Help link for details on "Compound Scale"
https://docs.bentley.com/LiveContent/web/MicroStation%20Help-v17/en/CreateModel.html
Interesting. I can see what it does, but I'm not sure how or when it would be effective.
