My company is trying to use Bentley View for users to view our documents, it works great for displaying a full drawing. My question is, is there an SDK or any means to create a menu, in which our users can turn on/off levels and reference files? Maybe even, would it be possible to send a file to the viewer, prior to opening the file, with the proper levels on and the proper reference files shown, without actually saving settings in the original file?
John
Hi John,
You can also customise the Ribbon and create your own ribbon tabs using the Customize Ribbon command.
Mark
OpenRoads Designer 2023 | Microstation 2023.2 | ProjectWise 2023
Answer Verified By: John Schenk
Best Answer yet, thanks Mark! I'm using the context menu to add these key in's.
