after Win10 reinstallation i can't install Powerdraft 10 update 8 which i've been using before. I get this information "Failed to copy payload for Microstation CONNECT Edition" over and over. Is there any solution for this problem?
Jacek
Thank you for your asnwers but unfortunately it won't help right now. Depending on version i get net framework payload issue or powerdraft payload issue. Right now i can use only update 5. I'm not subscriber anymore but i have full access to last versions of powerdraft which i was using before. I seems like download or win10 problem rather than subscriber access. I woul be grateful for any deployment package, maybe it will work
