Uninstall Bentley View Connect
I've tried using BentleyView Connect and I'm trying to remove it and all the numerous programs that were installed but I'm having this log error when I do so. This is the latest version downloaded only a week or so ago. I can obviously just delete the folders, but I'd like to ensure I'm not leaving anything behind in the registry etc.
It also won't let me repair, it immediately says it has repaired the installation, but then you can't load anything. Similar with modifying the installation.
Any ideas?
[6DB0:B9F0][2021-03-30T08:35:02]i001: Burn v3.11.1.2318, Windows v10.0 (Build 18363: Service Pack 0), path: C:\Users\Gladwell\AppData\Local\Temp\{03C5B946-A9F9-4F51-AA04-64090B2ADF3A}\.cr\vw10150075en_updt15.exe
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'LANGUAGE_3ccWin' to value 'ENU'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'BeApplicationToLaunchAfterInstallation' to value '[InstallDirectory]View\ActivationWizard.exe'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'BeApplicationToLaunchAfterInstallationArgs' to value '-productid:1000 -version:1000=[WixBundleVersion] -language:[LANGUAGE_3ccWin]'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'BeInstallFolderSuffix' to value ' 10.15.00.075'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'AddedPackagePageName' to value 'AddedPackagePage'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'PowerProductPackage_DiskSpaceCheckPath' to value '[InstallDirectory]'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'NotODPackageIdExtractionList' to value 'NDP462-KB3151800-x86-x64-AllOS-ENU;UsersAddedPackageInstaller'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'InstallDirectory' to value '[ProgramFiles64Folder]Bentley\Bentley View CONNECT Edition\'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'ConfigurationDirectory' to value '[CommonAppDataFolder]Bentley\Bentley View CONNECT Edition\'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'ConfigurationDirectory_V1' to value '[CommonAppDataFolder]Bentley\CONNECT Edition\'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'Custom_ConfigurationDirectory_Path' to value '[CommonAppDataFolder]Bentley\Bentley View CONNECT Edition\Configuration'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'LayoutSavePropertyList' to value 'InstallDirectory;ConfigurationDirectory;SharedConfigurationDirectory;InstallDesktopShortcut;OrganizationDirectory;WorkSpacesDirectory;WorkSpacesLabel'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'BePathPropertyList' to value 'InstallDirectory;ConfigurationDirectory;SharedConfigurationDirectory;OrganizationDirectory;WorkSpacesDirectory'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'AddedPackageAvailablePropertyList' to value 'InstallDirectory;ConfigurationDirectory'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'BeCustomRelatedBundleGuid' to value '{BAB2D504-BC14-45F4-99E7-C9C50A2C052A}'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'BundleHelpConfigurationWhatsNewChildHtml' to value 'GUID-47192D89-C83C-49EF-9398-599ECDA8F97E.html'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'BeIF_PromptCloseApplication' to value 'bentleyview'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'HDRPreviewExtension_x64_PossibleUserContextProductCode' to value '{9F7815C9-A323-4215-905C-73137D21BCC0}'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'BeBundleCulture' to value 'en'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'StandardPropertyList' to value 'AdminToolsFolder;AppDataFolder;CommonAppDataFolder;CommonFilesFolder;CommonFiles64Folder;CommonFiles6432Folder;ComputerName;Date;DesktopFolder;FavoritesFolder;FontsFolder;LocalAppDataFolder;LogonUser;MyPicturesFolder;PersonalFolder;ProgramFilesFolder;ProgramFiles64Folder;ProgramFiles6432Folder;ProgramMenuFolder;StartMenuFolder;StartupFolder;SystemFolder;TempFolder;TemplateFolder;WindowsFolder;WindowsVolume;'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'LayoutDirectory' to value '[WindowsVolume]BentleyDownloads\[WixBundleName]\'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'ProductsInstalledByBundle' to value 'NoProductList'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'BeBuildType' to value 'Release'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'BeNotBuildType' to value 'Beta'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'BeBundleShortName' to value 'View'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'BeWin64Bundle' to value 'yes'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'BeIFUseInternalResolver' to value '0'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'BeEulaFileName' to value 'Eula.htm'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing numeric variable 'BeUpdateNumber' to value '15'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'BundleHelpDocument' to value 'readMe_View_en.zip'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'VBA_LANGUAGE_PRGID_1033' to value '63644'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'VBA_LANGUAGE_PRGID' to value '63644'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'VBA_KB2803801_LANGUAGE_PRGID' to value '67804'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'BeVarProductCode_PowerProductPackage' to value '{CBBE447E-5AF1-3994-B4D2-865545A6ACB0}'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'BeVarProductCode_BentleyViewDocumentation' to value '{F7149EE4-1129-3922-BF84-1B49CE1E5ACB}'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'BeVarProductCode_VisualBasicCore' to value '{90120064-0070-0000-0000-4000000FF1CE}'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'BeVarProductCode_VisualBasicLang' to value '{90F60409-7000-11D3-8CFE-0150048383C9}'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'BeVarProductCode_PointTools32Extx86' to value '{6B722C27-1892-38C0-B216-C927CBE64763}'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'BeVarProductCode_DgnIFilterSetUpx64' to value '{2E873893-A883-4C06-8308-7B491D58F3D6}'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'BeVarProductCode_DgnThumbnailProvier' to value '{74A8C1AF-75E5-4653-95AF-222725B7D877}'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'BeVarProductCode_HDRPreviewExtension_x64' to value '{9F7815C9-A323-4215-905C-73137D21BCC0}'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'BeVarProductCode_ItgDgnDbImporter' to value '{AE4E79D2-D7DE-418F-9E7D-B58B62D7F4FA}'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'BeVarProductCode_ItgDgnDbImporter_v2' to value '{20D5AF52-66F2-4B6C-B329-F113B3764CC7}'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Initializing string variable 'BeVarProductCode_DPH' to value '{4196B3D1-C241-3448-8E4F-AE90154D62A1}'
[6DB0:B9F0][2021-03-30T08:35:02]i009: Command Line: '-burn.clean.room=C:\Users\Gladwell\Downloads\vw10150075en_updt15.exe -burn.filehandle.attached=640 -burn.filehandle.self=648'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\Users\Gladwell\Downloads\vw10150075en_updt15.exe'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'C:\Users\Gladwell\Downloads\'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\Gladwell\AppData\Local\Temp\Bentley_View_CONNECT_Edition_20210330083502.log'
[6DB0:B9F0][2021-03-30T08:35:02]i052: Condition 'VersionNT64  > v6.1 OR (VersionNT64 > v6.0 AND VersionNT64 < v6.2 AND ServicePackLevel >= 1)' evaluates to true.
[6DB0:B9F0][2021-03-30T08:35:02]i000: Setting string variable 'WixBundleManufacturer' to value 'Bentley Systems, Incorporated'
[6DB0:B9F0][2021-03-30T08:35:02]i000: Loading managed bootstrapper application.
[6DB0:B9F0][2021-03-30T08:35:02]i000: Creating BA thread to run asynchronously.
[6DB0:E070][2021-03-30T08:35:02]i000: Setting Culture Info to en
[6DB0:E070][2021-03-30T08:35:02]i000: Setting string variable 'BeSelectedLanguage' to value 'en'
[6DB0:E070][2021-03-30T08:35:02]i000: Setting string variable 'BeIFMainProcesCommandLineArgs' to value ''
[6DB0:E070][2021-03-30T08:35:02]i000: BentleyBundle Version 13.00.00.12
[6DB0:E070][2021-03-30T08:35:02]i000: TRY Set TLS 1.2
[6DB0:E070][2021-03-30T08:35:02]i000: Setting string variable 'WixExtractedTempFolder' to value 'C:\Users\Gladwell\AppData\Local\Temp\{D88CD8F9-E267-417A-8B02-6840F77D2026}\.ba'
[6DB0:E070][2021-03-30T08:35:02]i000: Setting string variable 'BundleCurrentPath' to value 'C:\Users\Gladwell\AppData\Local\Temp\{03C5B946-A9F9-4F51-AA04-64090B2ADF3A}\.cr'
[6DB0:E070][2021-03-30T08:35:02]i000: Setting string variable 'WixBundleLayoutDirectory' to value 'C:\Users\Gladwell\Downloads\'
[6DB0:E070][2021-03-30T08:35:02]e000: Using Layout File : C:\Users\Gladwell\AppData\Local\Temp\{D88CD8F9-E267-417A-8B02-6840F77D2026}\.ba\Setup.lyt
[6DB0:E070][2021-03-30T08:35:02]i000: Setting VisualBasicCore InstallLevel to 1
[6DB0:E070][2021-03-30T08:35:02]i000: Setting VisualBasicCoreKB2803801 InstallLevel to 1
[6DB0:E070][2021-03-30T08:35:02]i000: Setting VisualBasicCoreKB3061498 InstallLevel to 1
[6DB0:E070][2021-03-30T08:35:02]i000: Setting VisualBasicCorepatch InstallLevel to 1
[6DB0:E070][2021-03-30T08:35:02]i000: Setting VisualBasicLang InstallLevel to 1
[6DB0:E070][2021-03-30T08:35:02]i000: Setting VisualBasicLangPackKB2803801 InstallLevel to 1
[6DB0:E070][2021-03-30T08:35:02]i000: Setting DotNet462Full InstallLevel to 1
[6DB0:E070][2021-03-30T08:35:02]i000: Setting VCRedistx64 InstallLevel to 1
[6DB0:E070][2021-03-30T08:35:02]i000: Setting BentleyConnectClient InstallLevel to 1
[6DB0:E070][2021-03-30T08:35:02]i000: Setting BentleyAdvisor InstallLevel to 1
[6DB0:E070][2021-03-30T08:35:02]i000: Setting PowerProductPackage InstallLevel to 1
[6DB0:E070][2021-03-30T08:35:02]i000: Setting string variable 'PowerProductPackage.AddLocal' to value 'DefaultFeature,PPDesktopShortcut,OptionalFeature,Configuration,FileAssociationFeature'
[6DB0:E070][2021-03-30T08:35:02]i000: Setting PointTools32Extx86 InstallLevel to 1
[6DB0:E070][2021-03-30T08:35:02]i000: Setting DgnIFilterSetUpx64 InstallLevel to 1
[6DB0:E070][2021-03-30T08:35:02]i000: Setting DgnThumbnailProvier InstallLevel to 1
[6DB0:E070][2021-03-30T08:35:02]i000: Setting HDRPreviewExtension_x64 InstallLevel to 1
[6DB0:E070][2021-03-30T08:35:02]i000: Setting ItgDgnDbImporter InstallLevel to 1
[6DB0:E070][2021-03-30T08:35:02]i000: Setting ItgDgnDbImporter_v2 InstallLevel to 1
[6DB0:E070][2021-03-30T08:35:02]i000: Setting DPH InstallLevel to 1
[6DB0:E070][2021-03-30T08:35:02]i000: Setting BentleyViewDocumentation InstallLevel to 1
[6DB0:E070][2021-03-30T08:35:02]i000: Setting UserAddedPackagesInstaller InstallLevel to 1
[6DB0:E070][2021-03-30T08:35:02]e000: Failed for Package Id: PowerProductPackage_WinTabFeature
Bootstrapper Application Data is not found for the Feature: PowerProductPackage_WinTabFeature
[6DB0:E070][2021-03-30T08:35:02]e000: Failed for Package Id: LumenRT2017
Bootstrapper Application Data is not found for the Feature: LumenRT2017
[6DB0:E070][2021-03-30T08:35:02]i000: Setting string variable 'BePrimaryProductName' to value 'Bentley View CONNECT Edition'
[6DB0:E070][2021-03-30T08:35:04]i000: Running with UI
[6DB0:E070][2021-03-30T08:35:04]i000: Display is set to Full
[6DB0:E070][2021-03-30T08:35:04]e000: Loading component /SetupPagesLib;v1.0.0.0;component/InstallDirectorySelectionUserControl.xaml
[6DB0:E070][2021-03-30T08:35:04]e000: Loading component /SetupPagesLib;v1.0.0.0;component/WelcomeDialogInstallUserControl.xaml
[6DB0:E070][2021-03-30T08:35:04]e000: Loading component /SetupPagesLib;v1.0.0.0;component/UninstallVerificationUserConstrol.xaml
[6DB0:E070][2021-03-30T08:35:04]e000: Loading component /SetupPagesLib;v1.0.0.0;component/PPCustomWorkSpacesUserControl.xaml
[6DB0:E070][2021-03-30T08:35:04]e000: Loading component /SetupPagesLib;v1.0.0.0;component/DeploymentImageSettingsControl.xaml
[6DB0:E070][2021-03-30T08:35:04]e000: Loading component /SetupPagesLib;v1.0.0.0;component/FeatureConfigUserControl.xaml
[6DB0:E070][2021-03-30T08:35:04]e000: Loading component /SetupPagesLib;v1.0.0.0;component/ProxySettingsUserControl.xaml
[6DB0:E070][2021-03-30T08:35:04]i000: Register callbak=ProxySettingsPage
[6DB0:E070][2021-03-30T08:35:04]i000: Display Page=ProxySettingsPage
[6DB0:E070][2021-03-30T08:35:04]i000: Cannot Display Page=ProxySettingsPage
[6DB0:E070][2021-03-30T08:35:04]e000: Loading component /SetupPagesLib;v1.0.0.0;component/ErrorUserControl.xaml
[6DB0:E070][2021-03-30T08:35:04]e000: Loading component /SetupPagesLib;v1.0.0.0;component/MaintenanceUserControl.xaml
[6DB0:E070][2021-03-30T08:35:04]e000: Loading component /SetupPagesLib;v1.0.0.0;component/RepairSelectionUserControl.xaml
[6DB0:E070][2021-03-30T08:35:04]e000: Loading component /SetupPagesLib;v1.0.0.0;component/AddedPackageUserControl.xaml
[6DB0:E070][2021-03-30T08:35:04]e000: Loading component /SetupPagesLib;v1.0.0.0;component/WarningUserControl.xaml
[6DB0:E070][2021-03-30T08:35:04]e000: Loading component /SetupPagesLib;v1.0.0.0;component/CompanionProductInstallDirSelectionUserControl.xaml
[6DB0:E070][2021-03-30T08:35:04]e000: Loading component /SetupPagesLib;v1.0.0.0;component/CompanionProductConfigurationSettingsUserControl.xaml
[6DB0:E070][2021-03-30T08:35:04]e000: Loading component /SetupPagesLib;v1.0.0.0;component/CompanionProductSelectionUserControl.xaml
[6DB0:E070][2021-03-30T08:35:04]e000: Loading component /SetupPagesLib;v1.0.0.0;component/CompanionProductFeatureSelectionUserControl.xaml
[6DB0:E070][2021-03-30T08:35:04]e000: Loading component /LumenRTExtension;v1.0.0.0;component/InstallDirSelection.xaml
[6DB0:E070][2021-03-30T08:35:04]e000: Loading component /LumenRTExtension;v1.0.0.0;component/LumenRTUserInformation.xaml
[6DB0:E070][2021-03-30T08:35:04]e000: Loading component /SetupPagesLib;v1.0.0.0;component/RedefineWixPackageCacheUserControl.xaml
[6DB0:B9F0][2021-03-30T08:35:05]i100: Detect begin, 20 packages
[6DB0:B9F0][2021-03-30T08:35:05]i000: PCRA: Checking running instances.
[6DB0:B9F0][2021-03-30T08:35:05]i000: PCRA: Command Action - Install
[6DB0:B9F0][2021-03-30T08:35:05]i000: PCRA: Command Display - Full
[6DB0:B9F0][2021-03-30T08:35:05]i000: PCRA: No running instances.
[6DB0:B9F0][2021-03-30T08:35:05]i000: PCRA: Exiting from prompt.
[6DB0:B9F0][2021-03-30T08:35:05]i000: DetectBegin: e.Install=true, PlannedAction=Unknown, Setting InstallState=DetectedPresent
[6DB0:B9F0][2021-03-30T08:35:05]i000: SetCaseIndependentVariable: Check for VaribaleName=BeEmbeddedDisplay
[6DB0:B9F0][2021-03-30T08:35:05]i000: SetCaseIndependentVariable: Check for VaribaleName=SkipPendingSystemRebootCheck
[6DB0:B9F0][2021-03-30T08:35:05]i000: DetectBegin: Installed State of Package DetectedPresent
[6DB0:B9F0][2021-03-30T08:35:05]i000: Registry key not found. Key = 'SOFTWARE\Bentley\CONNECTAdvisor\{E8F76A19-488E-48F2-AD57-FB37115CC4FB}'
[6DB0:B9F0][2021-03-30T08:35:05]i000: Registry key not found. Key = 'SOFTWARE\Bentley\BentleyDesktopClient\Install'
[6DB0:B9F0][2021-03-30T08:35:05]i000: Setting string variable 'NetFramework46Version' to value '528040'
[6DB0:B9F0][2021-03-30T08:35:05]i000: Setting string variable 'VC14_vcredist_x64_Installed' to value '1'
[6DB0:B9F0][2021-03-30T08:35:05]i106: Calculating patch applicability for target product code: {90120064-0070-0000-0000-4000000FF1CE}, context: Machine
[6DB0:B9F0][2021-03-30T08:35:05]i106: Calculating patch applicability for target product code: {90F60409-7000-11D3-8CFE-0150048383C9}, context: Machine
[6DB0:B9F0][2021-03-30T08:35:05]i052: Condition '(NetFramework46Version >= 394802)' evaluates to true.
[6DB0:B9F0][2021-03-30T08:35:05]i052: Condition 'VC14_vcredist_x64_Installed >= v14.27.29016.0' evaluates to false.
[6DB0:B9F0][2021-03-30T08:35:05]i052: Condition 'BentleyConnectInstalledVersion >= v11.0.1.99' evaluates to false.
[6DB0:B9F0][2021-03-30T08:35:05]i052: Condition 'BentleyAdvisorItInstalledVersion >= v10.1.0.284' evaluates to false.
[6DB0:E070][2021-03-30T08:35:05]i000: ErrorPage Code: 0
[6DB0:B9F0][2021-03-30T08:35:05]i101: Detected package: VisualBasicCore, state: Present, cached: None
[6DB0:B9F0][2021-03-30T08:35:05]i101: Detected package: VisualBasicCoreKB2803801, state: Present, cached: Complete
[6DB0:B9F0][2021-03-30T08:35:05]i105: Detected package: VisualBasicCoreKB2803801 target: {90120064-0070-0000-0000-4000000FF1CE}, state: Present
[6DB0:B9F0][2021-03-30T08:35:05]i101: Detected package: VisualBasicCoreKB3061498, state: Present, cached: Complete
[6DB0:B9F0][2021-03-30T08:35:05]i105: Detected package: VisualBasicCoreKB3061498 target: {90120064-0070-0000-0000-4000000FF1CE}, state: Present
[6DB0:B9F0][2021-03-30T08:35:05]i101: Detected package: VisualBasicCorepatch, state: Present, cached: Complete
[6DB0:B9F0][2021-03-30T08:35:05]i105: Detected package: VisualBasicCorepatch target: {90120064-0070-0000-0000-4000000FF1CE}, state: Present
[6DB0:B9F0][2021-03-30T08:35:05]i101: Detected package: VisualBasicLang, state: Present, cached: None
[6DB0:B9F0][2021-03-30T08:35:05]i101: Detected package: VisualBasicLangPackKB2803801, state: Present, cached: Complete
[6DB0:B9F0][2021-03-30T08:35:05]i105: Detected package: VisualBasicLangPackKB2803801 target: {90F60409-7000-11D3-8CFE-0150048383C9}, state: Present
[6DB0:B9F0][2021-03-30T08:35:05]i101: Detected package: DotNet462Full, state: Present, cached: None
[6DB0:B9F0][2021-03-30T08:35:05]i101: Detected package: VCRedistx64, state: Absent, cached: Complete
[6DB0:B9F0][2021-03-30T08:35:05]i101: Detected package: BentleyConnectClient, state: Absent, cached: Complete
[6DB0:B9F0][2021-03-30T08:35:05]i101: Detected package: BentleyAdvisor, state: Absent, cached: Complete
[6DB0:B9F0][2021-03-30T08:35:05]i101: Detected package: PowerProductPackage, state: Present, cached: Complete
[6DB0:B9F0][2021-03-30T08:35:05]i104: Detected package: PowerProductPackage, feature: DefaultFeature, state: Local
[6DB0:B9F0][2021-03-30T08:35:05]i104: Detected package: PowerProductPackage, feature: PPDesktopShortcut, state: Local
[6DB0:B9F0][2021-03-30T08:35:05]i104: Detected package: PowerProductPackage, feature: OptionalFeature, state: Local
[6DB0:B9F0][2021-03-30T08:35:05]i104: Detected package: PowerProductPackage, feature: Configuration, state: Local
[6DB0:B9F0][2021-03-30T08:35:05]i104: Detected package: PowerProductPackage, feature: FileAssociationFeature, state: Local
[6DB0:B9F0][2021-03-30T08:35:05]i101: Detected package: PointTools32Extx86, state: Present, cached: Complete
[6DB0:B9F0][2021-03-30T08:35:05]i101: Detected package: DgnIFilterSetUpx64, state: Absent, cached: Complete
[6DB0:B9F0][2021-03-30T08:35:05]i101: Detected package: DgnThumbnailProvier, state: Absent, cached: Complete
[6DB0:B9F0][2021-03-30T08:35:05]i101: Detected package: HDRPreviewExtension_x64, state: Absent, cached: Complete
[6DB0:B9F0][2021-03-30T08:35:05]i101: Detected package: ItgDgnDbImporter, state: Absent, cached: Complete
[6DB0:B9F0][2021-03-30T08:35:05]i101: Detected package: ItgDgnDbImporter_v2, state: Absent, cached: Complete
[6DB0:B9F0][2021-03-30T08:35:05]i101: Detected package: DPH, state: Absent, cached: Complete
[6DB0:B9F0][2021-03-30T08:35:05]i101: Detected package: BentleyViewDocumentation, state: Present, cached: Complete
[6DB0:B9F0][2021-03-30T08:35:05]i101: Detected package: UserAddedPackagesInstaller, state: Absent, cached: None
[6DB0:B9F0][2021-03-30T08:35:05]i000: Detect complete Start
[6DB0:B9F0][2021-03-30T08:35:05]i000: SessionMutex: Creating new SessionMutex
[6DB0:B9F0][2021-03-30T08:35:05]i000: SessionMutex: Creating Mutex with Name={20040161-d214-4d9b-8390-9659a99df696}-InstallMutex
[6DB0:B9F0][2021-03-30T08:35:05]i000: SessionMutex: Created new SessionMutex with IsMutexOwned=True
[6DB0:B9F0][2021-03-30T08:35:05]i000: KBDetect: Current action is allowed to executed for KB check. ActionName=Install
[6DB0:B9F0][2021-03-30T08:35:05]i000: Trying to connect to BUDDI, with NetworkCredentials=NULL. Retry Count = 1. Local Retry Count = 1
[6DB0:B9F0][2021-03-30T08:35:06]e000: WaitForProxyAuthentication: Waiting for proxy authentication
[6DB0:B9F0][2021-03-30T08:35:06]i000: Fetch BUDDI Key, RetryCount = 0
[6DB0:B9F0][2021-03-30T08:35:06]e000: SetHeaders (): Added bootstrapper id in header, {20040161-d214-4d9b-8390-9659a99df696}
[6DB0:B9F0][2021-03-30T08:35:06]i000: Resolving Buddi Key. Attempt: 1
[6DB0:E070][2021-03-30T08:35:07]i000: Setting string variable 'BePlannedAction' to value 'Uninstall'
[6DB0:E070][2021-03-30T08:35:07]i000: PowerProductPackage AnalyzeFeatureConditions: LaunchAction=Uninstall
[6DB0:E070][2021-03-30T08:35:07]i000: PowerProductPackage AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: PowerProductPackage AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: PowerProductPackage_Configuration AnalyzeFeatureConditions: LaunchAction=Uninstall
[6DB0:E070][2021-03-30T08:35:07]i000: PowerProductPackage_Configuration AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[6DB0:E070][2021-03-30T08:35:07]i000: PowerProductPackage_Configuration AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[6DB0:E070][2021-03-30T08:35:07]i000: PowerProductPackage_OptionalFeature AnalyzeFeatureConditions: LaunchAction=Uninstall
[6DB0:E070][2021-03-30T08:35:07]i000: PowerProductPackage_OptionalFeature AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[6DB0:E070][2021-03-30T08:35:07]i000: PowerProductPackage_OptionalFeature AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=True
[6DB0:E070][2021-03-30T08:35:07]i000: PowerProductPackage_FileAssociationFeature AnalyzeFeatureConditions: LaunchAction=Uninstall
[6DB0:E070][2021-03-30T08:35:07]i000: PowerProductPackage_FileAssociationFeature AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: PowerProductPackage_FileAssociationFeature AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: PowerProductPackage_PPDesktopShortcut AnalyzeFeatureConditions: LaunchAction=Uninstall
[6DB0:E070][2021-03-30T08:35:07]i000: PowerProductPackage_PPDesktopShortcut AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: PowerProductPackage_PPDesktopShortcut AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: PowerProductPackage_WinTabFeature AnalyzeFeatureConditions: LaunchAction=Uninstall
[6DB0:E070][2021-03-30T08:35:07]i000: PowerProductPackage_WinTabFeature AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: PowerProductPackage_WinTabFeature AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: BentleyViewDocumentation AnalyzeFeatureConditions: LaunchAction=Uninstall
[6DB0:E070][2021-03-30T08:35:07]i000: BentleyViewDocumentation AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: BentleyViewDocumentation AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: UserAddedPackagesInstaller AnalyzeFeatureConditions: LaunchAction=Uninstall
[6DB0:E070][2021-03-30T08:35:07]i000: UserAddedPackagesInstaller AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: UserAddedPackagesInstaller AnalyzeFeatureConditions: Condition=AddedPackageFileXml OR BePlannedAction~="Layout", Action=
[6DB0:E070][2021-03-30T08:35:07]i052: Condition 'AddedPackageFileXml OR BePlannedAction~="Layout"' evaluates to false.
[6DB0:E070][2021-03-30T08:35:07]i000: UserAddedPackagesInstaller AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=False, IsSelectionEnabled=False, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: VisualBasicCore AnalyzeFeatureConditions: LaunchAction=Uninstall
[6DB0:E070][2021-03-30T08:35:07]i000: VisualBasicCore AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: VisualBasicCore AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: VisualBasicCoreKB2803801 AnalyzeFeatureConditions: LaunchAction=Uninstall
[6DB0:E070][2021-03-30T08:35:07]i000: VisualBasicCoreKB2803801 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: VisualBasicCoreKB2803801 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: VisualBasicCoreKB3061498 AnalyzeFeatureConditions: LaunchAction=Uninstall
[6DB0:E070][2021-03-30T08:35:07]i000: VisualBasicCoreKB3061498 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: VisualBasicCoreKB3061498 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: VisualBasicCorepatch AnalyzeFeatureConditions: LaunchAction=Uninstall
[6DB0:E070][2021-03-30T08:35:07]i000: VisualBasicCorepatch AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: VisualBasicCorepatch AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: VisualBasicLang AnalyzeFeatureConditions: LaunchAction=Uninstall
[6DB0:E070][2021-03-30T08:35:07]i000: VisualBasicLang AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: VisualBasicLang AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: VisualBasicLangPackKB2803801 AnalyzeFeatureConditions: LaunchAction=Uninstall
[6DB0:E070][2021-03-30T08:35:07]i000: VisualBasicLangPackKB2803801 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: VisualBasicLangPackKB2803801 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: DotNet462Full AnalyzeFeatureConditions: LaunchAction=Uninstall
[6DB0:E070][2021-03-30T08:35:07]i000: DotNet462Full AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: DotNet462Full AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: VCRedistx64 AnalyzeFeatureConditions: LaunchAction=Uninstall
[6DB0:E070][2021-03-30T08:35:07]i000: VCRedistx64 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: VCRedistx64 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: BentleyConnectClient AnalyzeFeatureConditions: LaunchAction=Uninstall
[6DB0:E070][2021-03-30T08:35:07]i000: BentleyConnectClient AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: BentleyConnectClient AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: BentleyAdvisor AnalyzeFeatureConditions: LaunchAction=Uninstall
[6DB0:E070][2021-03-30T08:35:07]i000: BentleyAdvisor AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: BentleyAdvisor AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: PointTools32Extx86 AnalyzeFeatureConditions: LaunchAction=Uninstall
[6DB0:E070][2021-03-30T08:35:07]i000: PointTools32Extx86 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: PointTools32Extx86 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: DgnIFilterSetUpx64 AnalyzeFeatureConditions: LaunchAction=Uninstall
[6DB0:E070][2021-03-30T08:35:07]i000: DgnIFilterSetUpx64 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: DgnIFilterSetUpx64 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: DgnThumbnailProvier AnalyzeFeatureConditions: LaunchAction=Uninstall
[6DB0:E070][2021-03-30T08:35:07]i000: DgnThumbnailProvier AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: DgnThumbnailProvier AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: HDRPreviewExtension_x64 AnalyzeFeatureConditions: LaunchAction=Uninstall
[6DB0:E070][2021-03-30T08:35:07]i000: HDRPreviewExtension_x64 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: HDRPreviewExtension_x64 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: ItgDgnDbImporter AnalyzeFeatureConditions: LaunchAction=Uninstall
[6DB0:E070][2021-03-30T08:35:07]i000: ItgDgnDbImporter AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: ItgDgnDbImporter AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: ItgDgnDbImporter_v2 AnalyzeFeatureConditions: LaunchAction=Uninstall
[6DB0:E070][2021-03-30T08:35:07]i000: ItgDgnDbImporter_v2 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: ItgDgnDbImporter_v2 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: DPH AnalyzeFeatureConditions: LaunchAction=Uninstall
[6DB0:E070][2021-03-30T08:35:07]i000: DPH AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: DPH AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: LumenRT2017 AnalyzeFeatureConditions: LaunchAction=Uninstall
[6DB0:E070][2021-03-30T08:35:07]i000: LumenRT2017 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=False, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i000: LumenRT2017 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=False, IsSelectionEnabled=True, IsExpanded=False
[6DB0:E070][2021-03-30T08:35:07]i052: Condition 'BePlannedAction="Uninstall"' evaluates to true.
[6DB0:B9F0][2021-03-30T08:35:08]i000: BeSkipKBCheck :
[6DB0:B9F0][2021-03-30T08:35:08]i000: Setting string variable 'BePlannedAction' to value 'Unknown'
[6DB0:B9F0][2021-03-30T08:35:08]i000: PowerProductPackage AnalyzeFeatureConditions: LaunchAction=Unknown
[6DB0:B9F0][2021-03-30T08:35:08]i000: PowerProductPackage AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: PowerProductPackage AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: PowerProductPackage_Configuration AnalyzeFeatureConditions: LaunchAction=Unknown
[6DB0:B9F0][2021-03-30T08:35:08]i000: PowerProductPackage_Configuration AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=False, IsExpanded=True
[6DB0:B9F0][2021-03-30T08:35:08]i000: PowerProductPackage_Configuration AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=False, IsExpanded=True
[6DB0:B9F0][2021-03-30T08:35:08]i000: PowerProductPackage_OptionalFeature AnalyzeFeatureConditions: LaunchAction=Unknown
[6DB0:B9F0][2021-03-30T08:35:08]i000: PowerProductPackage_OptionalFeature AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=False, IsExpanded=True
[6DB0:B9F0][2021-03-30T08:35:08]i000: PowerProductPackage_OptionalFeature AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=False, IsExpanded=True
[6DB0:B9F0][2021-03-30T08:35:08]i000: PowerProductPackage_FileAssociationFeature AnalyzeFeatureConditions: LaunchAction=Unknown
[6DB0:B9F0][2021-03-30T08:35:08]i000: PowerProductPackage_FileAssociationFeature AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: PowerProductPackage_FileAssociationFeature AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: PowerProductPackage_PPDesktopShortcut AnalyzeFeatureConditions: LaunchAction=Unknown
[6DB0:B9F0][2021-03-30T08:35:08]i000: PowerProductPackage_PPDesktopShortcut AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: PowerProductPackage_PPDesktopShortcut AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: PowerProductPackage_WinTabFeature AnalyzeFeatureConditions: LaunchAction=Unknown
[6DB0:B9F0][2021-03-30T08:35:08]i000: PowerProductPackage_WinTabFeature AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: PowerProductPackage_WinTabFeature AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=True, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: BentleyViewDocumentation AnalyzeFeatureConditions: LaunchAction=Unknown
[6DB0:B9F0][2021-03-30T08:35:08]i000: BentleyViewDocumentation AnalyzeFeatureConditions: BeforeAction Visible=True; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: BentleyViewDocumentation AnalyzeFeatureConditions: AfterAction Visible=True; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: UserAddedPackagesInstaller AnalyzeFeatureConditions: LaunchAction=Unknown
[6DB0:B9F0][2021-03-30T08:35:08]i000: UserAddedPackagesInstaller AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=False, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: UserAddedPackagesInstaller AnalyzeFeatureConditions: Condition=AddedPackageFileXml OR BePlannedAction~="Layout", Action=
[6DB0:B9F0][2021-03-30T08:35:08]i052: Condition 'AddedPackageFileXml OR BePlannedAction~="Layout"' evaluates to false.
[6DB0:B9F0][2021-03-30T08:35:08]i000: UserAddedPackagesInstaller AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=False, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: VisualBasicCore AnalyzeFeatureConditions: LaunchAction=Unknown
[6DB0:B9F0][2021-03-30T08:35:08]i000: VisualBasicCore AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: VisualBasicCore AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: VisualBasicCoreKB2803801 AnalyzeFeatureConditions: LaunchAction=Unknown
[6DB0:B9F0][2021-03-30T08:35:08]i000: VisualBasicCoreKB2803801 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: VisualBasicCoreKB2803801 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: VisualBasicCoreKB3061498 AnalyzeFeatureConditions: LaunchAction=Unknown
[6DB0:B9F0][2021-03-30T08:35:08]i000: VisualBasicCoreKB3061498 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: VisualBasicCoreKB3061498 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: VisualBasicCorepatch AnalyzeFeatureConditions: LaunchAction=Unknown
[6DB0:B9F0][2021-03-30T08:35:08]i000: VisualBasicCorepatch AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: VisualBasicCorepatch AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: VisualBasicLang AnalyzeFeatureConditions: LaunchAction=Unknown
[6DB0:B9F0][2021-03-30T08:35:08]i000: VisualBasicLang AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: VisualBasicLang AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: VisualBasicLangPackKB2803801 AnalyzeFeatureConditions: LaunchAction=Unknown
[6DB0:B9F0][2021-03-30T08:35:08]i000: VisualBasicLangPackKB2803801 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: VisualBasicLangPackKB2803801 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: DotNet462Full AnalyzeFeatureConditions: LaunchAction=Unknown
[6DB0:B9F0][2021-03-30T08:35:08]i000: DotNet462Full AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: DotNet462Full AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: VCRedistx64 AnalyzeFeatureConditions: LaunchAction=Unknown
[6DB0:B9F0][2021-03-30T08:35:08]i000: VCRedistx64 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: VCRedistx64 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: BentleyConnectClient AnalyzeFeatureConditions: LaunchAction=Unknown
[6DB0:B9F0][2021-03-30T08:35:08]i000: BentleyConnectClient AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: BentleyConnectClient AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: BentleyAdvisor AnalyzeFeatureConditions: LaunchAction=Unknown
[6DB0:B9F0][2021-03-30T08:35:08]i000: BentleyAdvisor AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: BentleyAdvisor AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: PointTools32Extx86 AnalyzeFeatureConditions: LaunchAction=Unknown
[6DB0:B9F0][2021-03-30T08:35:08]i000: PointTools32Extx86 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: PointTools32Extx86 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: DgnIFilterSetUpx64 AnalyzeFeatureConditions: LaunchAction=Unknown
[6DB0:B9F0][2021-03-30T08:35:08]i000: DgnIFilterSetUpx64 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: DgnIFilterSetUpx64 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: DgnThumbnailProvier AnalyzeFeatureConditions: LaunchAction=Unknown
[6DB0:B9F0][2021-03-30T08:35:08]i000: DgnThumbnailProvier AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: DgnThumbnailProvier AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: HDRPreviewExtension_x64 AnalyzeFeatureConditions: LaunchAction=Unknown
[6DB0:B9F0][2021-03-30T08:35:08]i000: HDRPreviewExtension_x64 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: HDRPreviewExtension_x64 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: ItgDgnDbImporter AnalyzeFeatureConditions: LaunchAction=Unknown
[6DB0:B9F0][2021-03-30T08:35:08]i000: ItgDgnDbImporter AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: ItgDgnDbImporter AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: ItgDgnDbImporter_v2 AnalyzeFeatureConditions: LaunchAction=Unknown
[6DB0:B9F0][2021-03-30T08:35:08]i000: ItgDgnDbImporter_v2 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: ItgDgnDbImporter_v2 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: DPH AnalyzeFeatureConditions: LaunchAction=Unknown
[6DB0:B9F0][2021-03-30T08:35:08]i000: DPH AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: DPH AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=True, IsSelectionEnabled=False, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: LumenRT2017 AnalyzeFeatureConditions: LaunchAction=Unknown
[6DB0:B9F0][2021-03-30T08:35:08]i000: LumenRT2017 AnalyzeFeatureConditions: BeforeAction Visible=False; IsChecked=False, IsSelectionEnabled=True, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: LumenRT2017 AnalyzeFeatureConditions: AfterAction Visible=False; IsChecked=False, IsSelectionEnabled=True, IsExpanded=False
[6DB0:B9F0][2021-03-30T08:35:08]i000: Detection complete planned action: Unknown
[6DB0:B9F0][2021-03-30T08:35:08]i000: DetectComplete (): Since action is =Install, performing CheckForAddOnRelatedBundle
[6DB0:B9F0][2021-03-30T08:35:08]i000: CheckForAddOnRelatedBundle (): CURRENT Bundle Tag properties IsAddOn=False, IsLangPack=False, IsPatch=False, IsWin64=True, Classification=, ServicePack=0
[6DB0:B9F0][2021-03-30T08:35:08]e000: CheckForAddOnRelatedBundle (): This product is not a Patch, LangPack or AddOn. Hence, not searching for related bundles
[6DB0:B9F0][2021-03-30T08:35:08]i000: WixInstallBA::SilentPlan
[6DB0:B9F0][2021-03-30T08:35:08]e000: baApplication_DetectWorkSpaceSetupCfg()::Not a major upgrade, no need to back up the WorkspaceSetup.cfg
[6DB0:B9F0][2021-03-30T08:35:08]i000: AutoCad Civil 3D ObjectEnabler:Searching
[6DB0:B9F0][2021-03-30T08:35:08]i000: AutoCad Civil 3D ObjectEnabler: No registered MicroStation for object enabler
[6DB0:B9F0][2021-03-30T08:35:08]e000: baCustomConfigurationPath:Start
[6DB0:B9F0][2021-03-30T08:35:08]i199: Detect complete, result: 0x0
[6DB0:E070][2021-03-30T08:35:09]i000: WixInstallBA::Plan
[6DB0:E070][2021-03-30T08:35:09]i000: WixInstallBA::SetupModel Plan
[6DB0:E070][2021-03-30T08:35:09]i000: SetupModel::Before Plan
[6DB0:807C][2021-03-30T08:35:09]i000: Before Plan Async
[6DB0:807C][2021-03-30T08:35:09]i000: SetupViewModel::Before Plan
[6DB0:807C][2021-03-30T08:35:09]i000: PlannedAction Unknown
[6DB0:807C][2021-03-30T08:35:09]i000: WixInstallBA::Before Plan Complete
[6DB0:807C][2021-03-30T08:35:09]i000: WixInstallBA::Engine Plan
[6DB0:B9F0][2021-03-30T08:35:09]i200: Plan begin, 20 packages, action: Unknown
[6DB0:B9F0][2021-03-30T08:35:09]e000: Error 0x80070057: Invalid action state.
[6DB0:B9F0][2021-03-30T08:35:09]e000: Error 0x80070057: Failed to get default request state for action.
[6DB0:B9F0][2021-03-30T08:35:09]e000: Error 0x80070057: Failed to set default package state.
[6DB0:B9F0][2021-03-30T08:35:09]e000: Error 0x80070057: Failed to process package.
[6DB0:B9F0][2021-03-30T08:35:09]e000: Error 0x80070057: Failed to plan packages.
[6DB0:B9F0][2021-03-30T08:35:09]i000: validateInstallSize (): Result=True
[6DB0:B9F0][2021-03-30T08:35:09]i000: Installation failed to Plan with error code -2147024809
[6DB0:B9F0][2021-03-30T08:35:09]i299: Plan complete, result: 0x80070057
[6DB0:E070][2021-03-30T08:35:09]i000: ErrorPage Code: -2147024809
