I’m exporting negative coordinates
I’m exporting negative coordinates, that are not correct. If I export Kmz it’s in the correct location. I can’t seem to figure why I can’t get correct SPC. I’m using connect.
  • Are you asking a question?
    How do you export coordinates?  What MicroStation tool do you use?
    What does that mean?  Google tells me...
    • Statistical process control
    • Staff product concessions
    • Supplementary protection certificates
    • etc
    Regards, Jon Summers
    LA Solutions
  • Jon thank you for the reply
    SPC= State Plane Coordinates
    i know how to export coordinates. I am just getting negative coordinates Y= -100000, X= -100000
  • can you post a copy  of your file here...
    You have a  GCS defined  right? and your units are defined correctly right?
    place a few objects like a  circle or  2  now tentative on the center of each circle and copy paste the message window values of the coordinates into note pad .. I hate typing.. now check the export  coords via  fence to enclose the 2 circles  and the export coordinates tool.. the txt result  should match your active note pad if not .. create new file and repeat...
    another check ,, test with know survey xref and  then turn on Bing maps in the view attributes if you units and  GCS are right bing should land where you expected.. now attach the file that gave you neg export coords .. does it land where expected in Bing view if not then your file is not right geo location.. us survey feet  sometimes cause problems.. fortunately for us in australia we dont  use them,  just meters..
    Can you open the same file in v8i and do the export and see if you still get neg coords... if not then CE is the problem and you may need to send your  file to bentley  support and see if it  needs a service ticket or its just your file...
    Lorys
    click link to PM me
  • i know how to export coordinates
    Me too!  But that doesn't tell us which of several methods in MicroStation you are using.  What's your workflow?  What's your starting point — as  asks, have you defined a Geographic Coordinate System (GCS)?  What result are you looking to create — a text file of coordinates or something else?
    LA Solutions
  • I’m exporting negative coordinates, that are not correct. If I export Kmz it’s in the correct location. I can’t seem to figure why I can’t get correct SPC. I’m using connect.
    Any progress?  Did you fix your problem if so please post how so others with similar problem can benefit ….
    Lorys
    click link to PM me
