I’m exporting negative coordinates, that are not correct. If I export Kmz it’s in the correct location. I can’t seem to figure why I can’t get correct SPC. I’m using connect.
Hey Jason,
I'm finding the same issue, did you happen to find a solution?
Thanks!
