I also have this begun having this problem. I have updated to the latest version of Connect and when I try to load a WMS from the
server the Save and Save and Attach are greyed out presumably because the Projected Coordinates did not come across from the server.
There is also an error message saying the WMS Map bounding box is invalid.
Is this still a defect or has something changed in the new version?
Any suggestions gratefully received!
regards
Mike
Not to mention for QGIS bug reporting and timelines are transparent not like this when you get reply that it will be fixed in some obscure and distant version and when new version comes out it is not that new version where it is fixed.
I actually succeeded in getting the 1.3 WMS services to display properly, when I manually edited the xwms file and replaced 1.3 with 1.1.1 in the <VERSION> tag _and_ edited ted <BBOX> to something correct, that I found in an old 1.1.1 file. But I wasted a LOT of time to get here ...
