Is it possible to create a table in MicroStation CONNECT and export that table into Excel?
I am aware of being able to import Excel into MicroStation, but not vice versa.
Thanks!
Hi Norah,
Enhancement 1098563 has already been logged for this requirement. The same is approved by the development team.
Hi Karan, I'm following up on the enhancement in question. Do you have an update?
You can refer to the following:
https://docs.bentley.com/LiveContent/web/MicroStation%20Help-v23/en/Reports.html
there is now an option to export report results to an excel worksheet.
David Trejo-Rodriguez said:there is now an option to export report results to an excel worksheet
That option has been available for several years. However, the OP is asking about a DGN table element. She asks, "Can a table's contents be exported as an Excel worksheet?" If I understand Karan Sharma correctly, that's what Enhancement 1098563 is about.
