Levels
Good afternoon.  I can't figure out the levels in Microstation.  As mentioned I am coming over from a CAD background, the layer functions in CAD were very easy to understand.  Select a line or block and put it on a layer.  And when you click on a line in CAD it will show you what layer its' on.  In Microstation I can't simply select a line and put it on a layer.  The software almost wants me to assign  all aspects of a level (line type, color, thickness) instead of just allowing me to put a line on a level where all those parameters are already set.  Its' very confusing, and takes a lot of time.  Anyone have any advice.  Thank you.
