<?xml version="1.0" encoding="UTF-8" ?>
<?xml-stylesheet type="text/xsl" href="https://communities.bentley.com/cfs-file/__key/system/syndication/rss.xsl" media="screen"?><rss version="2.0" xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:slash="http://purl.org/rss/1.0/modules/slash/" xmlns:wfw="http://wellformedweb.org/CommentAPI/"><channel><title>Microstation Connect Lag</title><link>https://communities.bentley.com/products/microstation/f/microstation-forum/212821/microstation-connect-lag</link><description>From what I&amp;#39;ve seen on the forum lag seems to be common, but I haven&amp;#39;t found a solution to fix the issue. When the user makes a selection on a drawing it is about a 2 second delay to actually select the objects in the drawing and then when they move they</description><dc:language>en-US</dc:language><generator>Telligent Community 12</generator><item><title>RE: Microstation Connect Lag</title><link>https://communities.bentley.com/thread/645658?ContentTypeID=1</link><pubDate>Tue, 20 Apr 2021 13:02:38 GMT</pubDate><guid isPermaLink="false">6dad98f5-dbc9-4c4d-a9ba-e9da8dc6aa8e:3cfa754c-336b-4ce9-a6f7-a7b6ac34cd7b</guid><dc:creator>Leonard Jones</dc:creator><description>&lt;p&gt;Could be UPF related. Try workarounds &lt;a href="/products/microstation/w/microstation__wiki/53337/microstation-crashes-on-start-up-upf-related"&gt;UPF related&lt;/a&gt;, &lt;a href="/products/microstation/w/microstation__wiki/53336/microstation-crashes-on-start-up-restore-defaults"&gt;RestoreDefaults&lt;/a&gt; (one at a time) and check if the lag goes away.&lt;/p&gt;
&lt;p&gt;Do also check if your graphics driver is updated to latest.&lt;/p&gt;&lt;div style="clear:both;"&gt;&lt;/div&gt;</description></item></channel></rss>
