In order to lock say "keypoint" snap every time we start a new command, from what I know, we can double-click the keypoint snap icon, vice-versa with multisnap to lock it.
Is there a way using keyin to lock keypoint snap type? I tried using keyin "snap keypoint" or "snap multisnap 1", the changes are temporary, once done with say drawing a line, the snap option will revert to the original snap type. Trying to use less mouse click, that's all.
Thank you!
A key-in that can be used for this capability would be using the LOCK SNAP settings.eg. LOCK SNAP MIDPOINT
Answer Verified By: Brian V
Exactly what I am looking for, thank you!
I would really appreciate it if you could click on the "This helped me" button at the bottom of my above post.
**Edit**
It would also be helpful if you could click on "Verify Answer" under the "More" button.
Hi Andrew, yes we should more give this feedback. But one forgets it too easily. Maybe there should be a popup to remind the user and ask if it helped or to verify.
Maybe though somebody comes up with a better idea because popups are often blocked or are just enervating... Maybe somebody can chime in and provide an example where that is solved in an elegant way.
Done!
