I'm trying to create a report with only distinct text values.
If I use Sorting and check Hide Repeated Values I get this but also empty records. I want the same result without the empty rows.
Krister
Krister Surell said:I'm trying to create a report with only distinct text values
Surely Groups & Aggregates are intended to answer your question?
Probably. I just cannot get it to work.
I have just one column containing the text element text. When I try to aggregate I get just the count, no text. What I really want is just the distinct text values. A SQL query would be: "select distinct text from table order by text".
I'm trying to see if reports can be a way to create a map legend from the information in file.
/Krister
Owner consultant at Surell Consulting AB
Krister Surell said:I just cannot get it to work
I find the report definition UI difficult to understand. Perhaps Mangesh.Shelar can advise?
Krister Surell said:A SQL query would be: "select distinct text from table order by text"
I understand. I think that Reports should have a well-defined grammar similar to SQL or XQUERY.
You can vote for my Idea.
Looks like getting distinct is not possible with existing report features. What about if we provide a "Distinct" operation in highlighted UI, will this help?
That would be great!
/Kister
