First off: I am using Microstation connect. I am operating locally, not on a server. I have "Auto-save design changes turned on."
I just had a crash and lost about two days of line work from my dgn. Im not sure how this could be considering the auto save function. The thing that is really strange is I've opened and closed the file multiple times over the past couple days so I know it has been saving the data. For some reason its all gone now. To be clear, the file isn't blank. It's as if it reverted to a state from four days ago or so.
Any one have any clever ideas how to recover my missing data?
David.
I have had several clients also report this. In their case the files are on a network server. MS will crash and some data is lost, but not all. Sadly i cannot reproduce the issue thus I am unable to create logs files that Bentley would require. I put it down to network connection issues, but in your case the files are local. Either way it shouldn't happen.
Would be good to hear if others have had similar issues
Ian
Hi David,
David Trotter said:I am using Microstation connect.
Even when not probably important in this discussion, it's recommended always to specify the used version exactly. There have been released nearly 20 versions of MicroStation CONNECT Edition so far, and as you can imagine, the current version CE U15.2 is very different from the original CE "version 0", released several years ago, in terms of features, stability and performance.
David Trotter said:Any one have any clever ideas how to recover my missing data?
The only way how to recover data is to use backup (when it exists).
DGN is binary proprietary format (even when based on Microsoft compound file specification), so when anything goes wrong, there is no tool (other than MicroStation itself) how to access the data.
What you can try, but I guess there is low probability of success, is to open the file as reference and if you have also MicroStation V8 installed, to use vrg tool (but usually this tool only crashes MicroStation).
Jan
Thanks for your response.
This is Microstation Connect Update 8 - Version 10.08.00.37
Also, I doubt this is of any consequence but all the line work I lost was on one level. So I'm not sure if the data was lost by time or by level somehow.
I have witnessed this is almost every build including 15.2.
Tried vrg but this tool is next to useless. Hence why I added an idea to get a proper repair tool added to the base software.
If the issue with the missing elements is related to a particular level you might like to have a look at the tools available for Level Audit which may locate any problems with Level Tables etc.
https://communities.bentley.com/products/microstation/w/microstation__wiki/8913/duplicate-level-tables
You might also like to look at using the MS_BACKUP configuration variable and use the BACKUP keying regularly to make a copy of your DGN files if you have concerns with your files.https://communities.bentley.com/products/microstation/w/microstation__wiki/25645/how-to-set-configuration-variable-ms-backup-to-create-a-backup-file-in-the-same-directory-where-the-actual-file-is-located-in-connect-edition
