MstnFontConfig no longer hides SHX fonts in Connect
For some time we have had a MstnFontConfig.xml file that has hidden all the fonts we don't typically use in Microstation V8i.
When migrating over to Microstation Connect, we've directed our workspace configuration at the same XML file.  Unwanted Truetype fonts and Resource file fonts are still hidden exactly as expected.  However, SHX based fonts are no longer hidden.  Has anyone else experienced this behavior?  If so do you have a work around?
I have provided all of my files to Bentley in a formal support request; they are able to reproduce the problem and acknowledge its an issue, but they do not have a solution for me.
Any insight is greatly appreciated.
Parents Reply Children
